Ana içeriğe geç
Tavana monte edilen kanatlı vantilatörler için onarım ve destek.
Matching up replacement capacitor
The capacitor in the top pic needs to be replaced. Can I replace it with the capacitor in the bottom pic? I know from reading other posts that the higher voltage on the red wire is fine, but I'm wondering about the configuration of the wires. The green and brown wires have the same rating in both, but are in reverse locations. The gray wires are in slightly different locations relative to the other wires too. I don't know if this matters. Thanks for your help!
Resim
Resim
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Rob,
You've got good instincts here; the second capacitor will indeed substitute for the original one just fine.
And yes, when you're wiring it up, ignore the positions of the wires coming out of the device and wire it strictly according to the colors of the wires. The two grey wires are actually wired together so it doesn't matter which one goes where, as long as it's gray. For the others, stick to the original wiring colors; red to red, green to green and brown to brown (or wherever each of these is connected on the original).
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks very much Jerry!
tarafından
Yorum Ekle
Yanıtını ekle
Rob D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 936
