SMC Issue or deeper issues? - How to fix?
So I have this MB Air A1466 2017 that had an issue with an undetected battery, we traced it to 2 blown caps and a funny SMC, We have replaced the caps and the SMC (Correct parts LM4FS1AH) and upon booting up the system was really sluggish and gave only ONE display resolution choice which was not the default (1275xXXX or something.... I thought an SMC / PRAM reset, using another GOOD Battery another 45w charger and even a fresh install (12.7.5) might help correct things but it didn't help. I then ran an apple diagnostics and here is the result (please read carefully)
The tech guy spent ages checking voltages etc and will look again on Monday....Until then maybe someone can shed some light? @oldturkey03. Hilfe!
I stumbled upon this post which lists the same 2 error codes
PFM006 & PPN001 error in diagnostics
So I did a 're-connect everything' but nothing changed....very slow to boot and fan sounds like it is at full speed... Quoting @danj At this point your logic board has a problem with one of the sensors voltage sense lines. Seems likely.
Bu iyi bir soru mu?
12 Yorum
@livfe can you tell us which capactiros have been replaced? That way we can look a little closer into the issue. Possibly a "wrong" SMC or possibly receiving wrong information based on other issues.
oldturkey03 tarafından
@oldturkey03 The SMC was LM4FS1AH , as for the Caps I will ask the tech guy. It is the same unit as from Battery Power OK But Battery Not Dectected......
livfe tarafından
@livfe I meant which specific caps. Location on the board or circuitry designator etc. :-) Not sure how well you know your tech guy but I would replace the substitute with the original and then check things out. A replacement has to be from an identical board as yours. You can't substitute since that could cause the issues that you are describing. To verify this, replace the SMC once more, but use yours.
@oldturkey03 Yes I know, I will update you on that once I got the info from the tech guy
livfe tarafından
@livfe awesome :-)
7 tane daha yorum göster
