Ana içeriğe geç
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Internal monitor Show double image
A friend of mine have this Powerbook G4 A1052 1.33.
The internal monitor now works only at 640x480 and 800x600, OS recognise it as "VGA Monitor", and the screen is "doubled", as you can see on the following image:
http://www.flickr.com/photos/77200474@N0...
On the external monitor everything works well.
I've already tried reset nvram, pram, etc (also via open firmware at boot), nothing changes. It's the monitor that needs to be changed?
Thank you
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try starting up in Safe Mode by holding down the Shift key on startup. If this solves the problem, remove the last thing you downloaded and installed.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Antonio Meloni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 491
