Ana içeriğe geç
Xbox One oyun kolu, 2016 yılında Xbox One S'in piyasaya sürülmesiyle tanıtılmış olup Windows 10/11 için Bluetooth desteği eklemiştir. Bu oyun kolu, Model 1537/1697 oyun kollarında bulunan birçok tasarım kusurunu düzeltir ve çok daha güvenilirdir. Bu oyun kolu, geliştirilmiş Model 1914 oyun kolu ile değiştirilmiştir.
Left Stick Constant Input Down
I attempted some maintenance on my controller a couple of weeks ago, using some 99% IPA to scrub the potentiometers of the joysticks to my controller, as well as the joysticks themselves, and other areas of the motherboard. However, as a result, the left stick has been constantly giving input downward according to the direction of the stick.
I have attempted to clean the potentiometers again, as well as replace the left stick just today, to no avail on resolving this new issue.
Upon testing for continuity, I noticed that the pins in the potentiometer intended to input vertical LS movement do not seem to have a connection. This is after clarifying that all of the opposite pins on all three of the other potentiometers in the controller returned a status of continuity existing between them respectively.
I am wondering, then, what the problem could be with the controller. Thank you for reading into my inquiry.
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Aiden!
How are the solder pads? Still good? If those are damaged it can cause the issue you are having.
Also, check the other components near the sticks on the motherboard, maybe something is damaged there.
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hi there, what could I do in the event that the solder pads are damaged? How could I bring the controller back to operation in such a case?
tarafından
Depends on how it is damaged! Can you remove all the solder and sent us a new photo? Thanks in advance!
tarafından
Yorum Ekle
Yanıtını ekle
Aiden sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 255
