Ana içeriğe geç
Huawei Watch 3, Huawei'nin kendi işletim sistemi olan HarmonyOS 2 üzerinde çalışan ilk saatidir. Başlıca özellikleri 1,43 inç AMOLED ekran paneli, eSIM, kalp atış hızı ve SpO2 sensörleri ve dijital kurma kolu olup 14 güne kadar pil kullanım süresi sunar.
Power button is not working
Hi, there guide to change and replace Huawei Watch 3 crown(power button). Button pressing is not working.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum:
Is your button clicking? Did you get it fixed?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
There is an excellent video on YouTube by GOODTIMES TECH that shows an identical issue with Huawei watch which shows the problem being related to a plastic piece that is worn causing the power button to not activate the switch.
The audio isn’t very clear but very easy to follow and shows successful remedy for the button issue.
You can find it here:
https://m.youtube.com/watch?v=e-_h8R2IXc...
If you’re battery isn’t dead this will more than likely be the issue with your watch.
cheers
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
My button clicks good. No worn plastic piece. Maybe corrosion underneath the clicking part onto the PCB ribbon behind.. Even some electronic contact liquid cleaner didn't have any effect.
It still shows the time, and sensors are right, but can't launch any app anymore.
tarafından
Hello! Same issue like Mars Eye, button click feel good, scroll and long (reseting) button clicks works.
Only the single click doesn't respond. Do anyone have a solution already?
tarafından
Yorum Ekle
Yanıtını ekle
Tuomas Mäkinen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 40
Son 30 gün: 86
Her zaman: 1,903
