Removing scratches from the back?
I got a iPod nano for 10$ and it does work, but it is scratched up like mad on the back
Is there anything i can try to to remove some, if not all of the scratches?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Nick, what I do with the older back plates is to use some buffing compound and a buffing wheel. This usually removes most scratches Depending on how deep they are). Your Nano is a bit small and tough to hang on to, so be careful if you use a wheel. Otherwise you will have to buff it by hand. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Most of them are the light ones that are pretty typical on shiny back iPods, a few lighrt scratches
Yes, they should buff out.
i'll have to try it and get a case to avoid this again, although it's commonplace, i do want to keep it minimal
Thanks for accepting my answer. Yes, a case would be good, since they do get banged up quite a bit. Good Luck.
this one has dings on the faceplate from being dropped, and scratches too, pretty clear old owner, who was a friend never used a case
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 1,521
