power supply board replacement part
i'd like to get a power supply board (flextronics) for my 27" thunderbolt display. are these for sale? are they same is what is in a 27" iMac?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This should still be under warranty. If it is, I would certainly get the extended AppleCare warranty.
Bu yanıt yardımcı oldu mu?
Hi
Power supply board part numbers are: 661-6048, 661-5543. I found boards available for sale on ebay and maybe available for other apple spares suppliers if you search using the part numbers.
Will both power supply board with the different part numbers be compatible for a Thunderbolt Display?
The question is still open, are those part numbers interchangeable or: what's the difference?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 6,650
7 Yorum
Hi aaronoehlke. Did you find the power supply board for sale?
SW tarafından
I also need this - it makes a weird noise - and it is coming from the power supply...
Antonkjaer tarafından
Have you got the power supply?
Karsten Bundgaard tarafından
Hi Karsten,
Nope - have you got one in Denmark?
Unfortunatly not!
2 tane daha yorum göster
