Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Bluetooth and Wifi working without Airport/Bluetooth Board connected?
Not to look a gift horse in the mouth, but.....
I was recently repairing something else and found myself (disabled, low vision, low dexterity, tremor) having to reconnect the wretched little antenna cable connectors to the Bluetooth board. After about 4 hours of continuous work, realizing the futility of this, I gave up and left the cables disconnected, assuming I'd have to buy a USB adapter to replace the Wi-Fi/Bluetooth functions.
But....... My Wi-Fi and Bluetooth are working fine without them.
What's going on there? What do the antennae cables really do?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The logic board connector presently is the antenna! That little pin point in the middle. The wire connects to a much larger exposed metal piece which is fully exposed outside of your metal case.
So while it appears to work the AirPort board is now being stressed over time it will fail in this state as the expected load is missing.
Best to find a friend to help you being care full not damaging the connector or cable.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
That makes sense - thank you! I plan to have it fixed soon.
tarafından
Yorum Ekle
Yanıtını ekle
biterate sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 29
