Ana içeriğe geç
Meu carro tá aquecendo muito o q pode ser?
Fiat strada adventure 2012
Translation Spanish - English
My car is overheating, what could it be?
Fiat Strada Adventure 2012
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@pamelasilv91580 first thing to check is always the coolant level. Make sure you have enough in it. After that you want to make sure that your fan does come on. If not you will have to check the fan itself as well as the fan control switch. If all that checks out than there is a possibility that this is related to a bad water pump, but check the easy things first. Let us know what exact engine size your 2012 Fiat Strada Adventure has so we can try and find more specific information for you.
Translation
@pamelasilv91580 Lo primero que hay que comprobar siempre es el nivel del refrigerante. Asegúrate de que tiene suficiente. Después, asegúrate de que el ventilador se encienda. Si no es así, tendrás que comprobar el ventilador en sí y el interruptor de control del ventilador. Si todo está bien, es posible que se deba a una bomba de agua defectuosa, pero comprueba primero las cosas fáciles. Cuéntanos qué tamaño de motor exacto tiene tu Fiat Strada Adventure 2012 para que podamos intentar encontrar información más específica para ti.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Pâmela Silva sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 25
