Ana içeriğe geç
Üretiminin ilk yılında Santa Fe, iki motor ve şanzıman kombinasyonundan biriyle sunulmuştu. Kuzey Amerika'da, yakıt tasarruflu 2.4 L dört silindirli motor standart donanımdı ve 5 vitesli manuel veya 4 vitesli otomatik şanzımanla eşleştirilebiliyordu.
My window glass doesn't work well
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
A better description of the problem you're having with your window would help, but I wouldn't necessarily replace the window motor as the first step, as there's always the possibility it's a problem with the window regulator; that's the mechanism that the window motor drives that moves the window up and down. The connecting belt or cable can wear out or break, and the tracks can get out of alignment which can bind up the window in certain parts of its travel. Those possibilities should be investigated as well, along with the possibility that it could be an issue with the window switch rather than the window motor.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Verify your window motors are getting full voltage and then verify your motor ground has good continuity, if both are good replace the motors; they're old and weak.
Puan 0
Yorum Ekle
Yanıtını ekle
maamoon alloo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 273
