Ana içeriğe geç
Raspberry Pi 4, Raspberry Pi Vakfı tarafından geliştirilen çok yönlü bir tek kartlı bilgisayardır ve Raspberry Pi ürün serisinin dördüncü neslidir.
USB ports are dead
Hi guys. I have a RaspberryPi 4B 4GB (newer version) that had 9V instead of 5V put through the USB-C power input according to owner.
Surprisingly it boots and works, but ethernet and USB ports are dead. I replaced the BCM54213PE and VL805 chips I took from a donor board - ethernet works fine now, but no luck with USB.
I also replaced the crystals next to both of those chips - didn't help either.
Any ideas what else I should check?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Fixed it in the end :) So in total I replaced both chips and also quartz crystals next to them on both sides, then also replaced a diode next to the Ethernet port and USB 3 and two chips that look like filters between the BCM54213PE and PoE.
None of that actually did the trick in full, so then I reflowed VL805 IC and voila - "we have picture" (c) Sorin :D
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Did you post your question in the Raspberry Forum area?
I would check the power side of the USB sockets is power getting through? Does a powered USB hub allow the USB device to work?
Puan 0
1 Yorum:
Oh absolutely, thanks, but actually I already figured it out :) thanks for the heads up anyway :)
tarafından
Yorum Ekle
Yanıtını ekle
in_sympathy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 79
Her zaman: 1,099
