Toshiba Satélite A105 S457
Originalmente venía con Windows Vista y la actualicé a Windows 7. También aumenté la RAM a 2 GB .
Se podrá actualizar a Windows 10? Alguien sabe?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hey @miguelcano!
I'd say it'd technically work with Windows 10, but it probably won't be much fun to use. Because it is so old, it will have trouble running that new operating system and may be unusable slow. And, as @mike pointed out, you can't upgrade the RAM any further and the hard drive interface is a major bottleneck.
A better solution would be to look into alternatives to Windows. If you don't require a specific software program that only runs on Windows, I'd look into installing Linux on your machine. There are many different versions (Called "Distros"), that are optimized for different uses. My personal favorite for older machines is called AntiX. It runs on practically anything and provides a responsive, modern experience on outdated hardware. If you go with AntiX instead of Windows, you may even be able to use it without performing any upgrades! It doesn't look amazing, but it will do almost everything most people need from a computer. Just Google it, and you should find it and instructions for installation.
If you have any questions, ask!
Good luck!
Hola @miguelcano!
Yo diría que técnicamente funcionaría con Windows 10, pero probablemente no sea muy divertido de usar. Debido a que es tan antiguo, tendrá problemas para ejecutar ese nuevo sistema operativo y puede resultar inutilizable y lento. Y, como señaló @mike, no se puede actualizar la RAM más allá y la interfaz del disco duro es un cuello de botella importante.
Una mejor solución sería buscar alternativas a Windows. Si no necesitas un programa de software específico que solo se ejecute en Windows, yo buscaría instalar Linux en tu máquina. Hay muchas versiones diferentes (llamadas "distribuciones"), que están optimizadas para diferentes usos. Mi favorita personal para máquinas más antiguas se llama AntiX. Se ejecuta prácticamente en cualquier cosa y proporciona una experiencia receptiva y moderna en hardware obsoleto. Si eliges AntiX en lugar de Windows, ¡incluso podrás usarlo sin realizar ninguna actualización! No se ve increíble, pero hará casi todo lo que la mayoría de las personas necesitan de una computadora. Solo tienes que buscarlo en Google y deberías encontrarlo, así como las instrucciones para su instalación.
Si tienes alguna pregunta, ¡pregúntala!
¡Buena suerte!
Bu yanıt yardımcı oldu mu?
This Toshiba Satellite A105-S4284's maximum RAM is 4 GB and its SATA interface is only 1.5Gb/s so even an SSD would be not be much faster.
Thanks for letting me know! I'll start doing my homework before posting answers!
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 43
