Ana içeriğe geç
Sony DualSense Edge (CFI-ZCP1) kablosuz kontrolcü, Ocak 2023'te piyasaya sürüldü. DualSense'e kıyasla değiştirilebilir oyun çubuğu modülleri ve diğer iyileştirmeleri içerir.
Stick Module always out stock, Any possible Solutions?
With the Stick Module impossible to get, I was thinking of just replacing the potentiometer with a hall effect one is that possible? are the hall effect available in the market compatible with the module
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
I’m afraid you need to replace the whole joystick to get that to work. Unfortunately you need to complete de-solder the old one and solder the hall effect joysticks in. But it is worth it!
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
so open up the module i have, i understand soldering part i dont mind. But is the hall effect compatible with the stick modules for the DualsenseEdge.
tarafından
Ohh sorry, you want to know if the Hall effect joysticks are compatible with the Dual Sense controller, right? The answer is, yes, they are! Part: https://www.aliexpress.us/item/325680609...
tarafından
Thank you! i was able to order one yesterday arrived today. Now the challenge is removing the soder in the module. it is In there pretty deep.
tarafından
My pleasure! Yes, this is the most difficult part. They are soldered on with "lead free" solder. So you need to turn up the heat to 400-450 to get it out. Once it is out, you can solder the new one back in which is easier to do! Good luck with the repair!
tarafından
So, did it work? Is it much different from DualSense modules?
EDIT: and do you need to get Edge-specific module replacements or classic DualSense will work too?
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
SlicedAnddiced sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 1,438
