I take you've got a copy of your songs in the laptop.
Tell me: does your nano charge when you connect it to the USB cable?
Is the USB cable the original one or a third party spare?
If your Nano doesn't charge, there may be an issue in the cable or the dock connector.
So, try to connect it to a different USB port. Failing that, change the USB cable. Failing that, you should seek technical help.
If your Nano charges fine, but it's just an issue with iTunes, check if its a Windows Machine or an OS X machine.
And what machine has your mother.
See, an iPod Nano set to work with OSX doesn't work with Windows, and viceversa, forcing the user to reformat it again.
If you're in Windows, you may try to reinstall iTunes.
Failing that, check this official guide from Apple
http://www.apple.com/support/ipodnano/as...
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
Do you get any errors on itunes? If you do, please tell them here, if you
don't get any, the iPod could be faulty.
Daniel tarafından
Is your mother's iPod recognized on your computer/iTunes? Have you tried to place it in Disk mode?
" Before placing the iPod into Disk Mode, verify that it has a charge.
Reset the device by pressing the Sleep and Volume Down buttons simultaneously until the display turns black. This should take about eight seconds.
When the display turns black, hold down the Volume Down and Volume Up buttons simultaneously until the device enters Disk mode." from here One of the problems that you also might run into is that the libraries got overwritten. iTunes does not like separate iPods and separate libraries....;-)
oldturkey03 tarafından
