Ana içeriğe geç
Repair information and guides for MacBook Pro 15" Retina Display laptops from 2012 and continuing.
Battery empty after sleep, but battery is not empty
After replacing the battery with ifixit replacent, when the macbook is in sleep mode for a while the macbook won't boot because of empty battery.
But when you plugin the power cord the battery is not empty at all eg 95% and is working normaly on battery power after unpluging the power cord.
i calibrated the battery after installing and did a SMC & PRAM reset, repeated it but no solution.
Also the battery is not sticking i used the fix kit to remove the old glue.
Any suggenstions are welcome
Update (08/21/24)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
I'm surprized that the new battery i bought is already 9 years old
tarafından
@jos33241 The image is not linked to view....
tarafından
@livfe - Fixed
tarafından
@jos33241 - Do to COVID some battery makers salvaged microcontrollers from older batteries as the suppliers were unable produce the part.
Your issue is not the battery.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Within the charging logic is a set of MOSFETs which toggle the power between the three points, the power line, battery and the logic board.
So, here the logic from the battery to the logic board is not enabling, yet it’s possible power from the MagSafe is getting to the battery and clearly getting to the logic board circuitry. Let’s get a better view of things, install this gem of an App CoconutBattery, first letting the battery run down a bit so the charger will need to charge the battery, now with the charger plugged in the MagSafe LED should be Amber give it a moment so CoconutBattery is refreshed and take a snapshot of the Apps main window posting it here so we can see things.
So could you’ve damaged something taking the old battery out? Once we see the CoconutBattery snapshot we’ll know more.
As for the adhesive issue, these systems still used a terrible approach, I clean the plastic sheet of the adhesive and then apply a set of Command Adhesive strips from 3M (get the heavy duty refills or get a roll of the special tape) I use two well spaced strips per cell leaving the pulls exposed so the next time it’s not a battle. Do make sure the uppercase side is spotless and oil free.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jos sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 52
