Ana içeriğe geç
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
DualSense V3, three times yellow light after "repair"
Hi!
Today I cleaned the potentiometers because of the left stick drift and then the problem happened.
While dissasembly and assembly I checked not to pinch the ribbons, the red, black, green and yellow wires are soldered correctly, everything seems fine but the %#*@ thing does not work. I reasoldered those wires a second time and checked with a multimiter, it seems fine. I also checked the ribbons from the adapting triggers, also everything ok.
Please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
Sounds like something is damaged on the motherboard! Please check all the components to see if nothing is missing! Also check if the traces are okay!
If possible, please share some pictures with us! Thanks!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
hey, if I understand correctly 3 blinking lights means that something is causing a short in the motherboard. in my case, a small hair had gotten itself stuck under the joystick. Removing it fixed it.
One trick you can use to troubleshoot the fault is to keep disassembling the controller while having a cable plugged in and pressing the ps button until the 3 blinking lights become 2 (no battery), that will tell you what the problem is.
Puan 1
Yorum Ekle
Can someone please help me with this? I have the same issue where the light would flash orange three times. I have tried a different battery as well - same issue. I have taken photos of the front and back of the board. Many thanks.
Puan 0
1 Yorum:
I just solved the triple yellow light thanks to TheHooligan95's comment, with the battery disconnected when plugged by USB it enters like a diagnostics mode by flashing the lights, three yellow flashes and something is broken, two yellow flashes and it should be ok once the battery is plugged back.
On my case one of the traces from the ribbon that connected to one of the joysticks was shorted, I could carefully straighten the trace and it's working again
tarafından
Yorum Ekle
Yanıtını ekle
Voyteck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 74
Her zaman: 817
