Ana içeriğe geç
IXUS 275 = Released on Feb 2015 IXSUS 285 = Released on Jan 2016
len error stuck, auto shutdown
When I tried to turn on the camera, an error message stating "lens error" appeared, followed by an automatic shutdown. Is there any method or tutorial available to fix this issue? Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@frankieyim t depends where and why it is stuck. If it is the outside of the lens that pushes it in, you could try and bend it back. Most likely the lens mechanism is jammed. This may happen because of dirt getting in, or because the lens barrel got knocked. If the extension/zoom part is of track than you may have a tougher time with it. Start by following the ideas on here
Ultimately if nothing works you may have to replace the lens since repair parts are almost impossible to obtain.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Frankie Yim sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 60
