The laptop could not power ON
The laptop could not power ON. I discovered that power is entering from the power pack.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi!
Did you tried a hard reset first?
Please remove the charger from the laptop. Then do the following:
Now it should boot up again (this can take some time and it’s normal that the LED is flashing).
After this, make sure you download and install the latest BIOS version.
If this failed, you probably need to replace the motherboard to get it working again.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 116
