Ana içeriğe geç
The Latitude E7440 is an ultrabook by Dell released in November 2013, identified by model number 730-6964, with a fully usable touchscreen display. It is a high end business laptop built to be portable and sleek yet sturdy.
Ivalod partition and error pxe e61
Invalid partition table!
Intel(R) Boot Agent GE v1.5.50
Copyright (C) 1997-2013, Intel Corporation
PXE-E61: Media test failure, check cable
PXE-MOF: Exiting Intel Boot Agent.
No Boot Device Found. Press any key to reboot the machine_
From dell lattitude e7440
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@ukomfarmasi Enter your computer's BIOS and check if your computer's HDD still shows. This error is the most common error when you have a failed HDD. It can't find the OS, so it's moving down the list to other possible boot devices until it finally displays the No Boot Device Found.
To enter the BIOS, power on the system and then go to BIOS Setup by pressing the F2 key.
You can quickly verify this by setting the boot order to USB and create a bootable USB drive. Then start your computer from that. If it properly functions, you know you will have to replace your HDD.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I encounter the same problem with Dell Vostro 3560.
It does NOT show USB at all as a possible boot option.
As far as I have learned from the web, some BIOS versions have a System configuration -> USB configuration -> Enable boot support
option, but my BIOS does not have this.
The BIOS is still the original one, with no updates applied to it.
Can you please explain whether booting from a USB is possible at all on this model ?
Thanks a lot in advance & Best Regards,
Iudith Mentzel
tarafından
Yorum Ekle
Yanıtını ekle
UKOM Farmasi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 101
