Ana içeriğe geç
The machine switches off when starting
The heating element works. The pump works fine with cold water, but when I switch over to hot, the whole machine shuts down after about 1 second. I have tried descaling, although not easy to do with so short pump bursts. Any ideas?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
My idea: because the fault appears when heating, the heater has a electrical short. Open the machine and find the heater. You can measure its resistance, it should be around 40 Ohms for a 230 V machine. If not, replace it.
Another possibility: the issue is a broken capacitor on the motherboard, find the motherboard. The capacitor should look like these e.g. in Nespressos. Replace it, (or both, If there are more) hopefully this will do the trick.
Nespresso CitiZ Kondansatörler Görseli
Kılavuz
Nespresso CitiZ kondansatör değişimi
Zorluk:
Orta
Dolce Gusto Oblo Su haznesi bağlantı grubu contası Görseli
Kılavuz
Dolce Gusto Oblo su haznesi bağlantı grubu conta değişimi
Zorluk:
Orta
40 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks VauWeh, it was the capacitors. I changed them a couple of years ago, but the symptoms then were different (must have been the other one, there are two) so I didn't think that was the problem. Anyway - it works - hurray!
tarafından
Congratulations! Repair is war on entropy!
tarafından
Yorum Ekle
Yanıtını ekle
Olle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 56
Her zaman: 2,256
