Ana içeriğe geç
2016 yılının başlarında piyasaya sürülen, 2015 model Retina MacBook'un güncellenmiş versiyonu için onarım bilgileri ve kılavuzları. Model A1534 / EMC 2991
Force Trackpad Weak After Assembly
Hey all at iFixit.
I am working on this MacBook, and I have been using it for a few months now without any issues. Yet, I couldn't help but notice that the force trackpad was very weak. I could hear the click, but I could barely even feel it. I took the machine apart, but the trackpad felt fine. After a snapped the lower case back on, the trackpad became weak again. Something happens when I snap the lower case on, and the trackpad loses power. I feel like something might be bent on the lower case, but nothing appears off.
Should I look somewhere else? Why would the trackpad lose power by simply putting on the lower case?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I would take a straight edge to see if the case is not caved in either side. Also check if the case is warped so diagonal corners appear to not lay flat on a known flat surface.
If you don’t detect any issues then I would summarize the TouchPad is damaged and will need replacement.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
@danj - Turns out the lower case was bent a little, I took some clamps and bent it back in place, trackpad feels great now!
tarafından
Yorum Ekle
Yanıtını ekle
Jadon Lyon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 213
