Ana içeriğe geç
17 Şubat 2022 tarihinde piyasaya sürülmüştür
Phones display is not working
My phones display was in perfect condition no dropping or nothing happened it suddenly became unresponsive the volume buttons and everything is working but the touch is unresponsive I restarted it also but nothing happened
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
4 Yorum
Disply change
tarafından
@oneplusnor84691
See the Most Helpful Answer below for what to do.
tarafından
Display changing
tarafından
@eramu
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you have a backup of your phone or aren't worried about losing data, it would probably be a good idea to do a complete wipe back to factory settings to determine whether you're facing a software or a hardware issue. The full restore should eliminate any possibility of it being a software problem, but if the touch screen works after the restore then you've obviously run into some kind of software issue.
If you don't have a backup, it may be possible to work around the non-responsive touch screen by plugging in a USB-C mouse to the phone and using that to substitute for the touchscreen.
Otherwise your most likely fix is going to be to replace the screen. The digitizer that's responsible for handling touch inputs is fused to the AMOLED display so they have to be replaced as one assembly. On your phone there are actually two ways to replace the screen; with or without the frame. When you buy a screen with the frame, it comes already mounted on the midframe so the process of replacing the screen consists of basically gutting the phone - removing all of the components - and moving them to the new screen+frame assembly. That's the generally recognized best practice for a new screen; you don't have to worry about sealing the screen against liquid ingress nor have any concerns about gluing it down and then holding it in place while it dries. Plus you get a new midframe so the phone looks brand new. Here's a guide showing how to do that repair.
Manuals / OnePlus Nord CE 2 / Full Screen - Nobody Calls Me Chicken
The other way to do it is to separate the display from the midframe, clean off all the old glue from the midframe and glue the new screen down. You'll have to secure it with rubber bands or weight for a period of time until the glue dries. I wasn't able to locate any iFixit-style guides for that repair on your phone, but I did find a YouTube video that looks like the guy knows what he's doing.
One Plus Nord CE2 Display Replacement And Price - One Plus Nord CE2 - YouTube
Although my preference is normally to go with the screen+frame procedure, in this case the screen only replacement is quite straight-forward and you don't have to disassemble hardly anything to get to the display connector so that's what I would recommend for you.
As far as a replacement part, you'll want to search using the model number of your phone to ensure you get the right replacement. In my cursory search for screens, I saw that there are a couple of options available to you; you can get them with and without the frame, depending on which method you want to use, and you can buy cheaper TFT LCD versions of the screen vs. the original AMOLED displays. The LCD screens will be substantially cheaper, but will have a lower quality picture and because it also has a backlight it will use more battery power, meaning you won't be able to go quite as long between charging.
Because I don't have your model number I haven't posted any examples of replacement screens, but they are easy to find on such sites as Amazon, eBay or AliExpress, among others.
Good luck and let us know how it all turns out for you!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
  1. Forced restart (varies by phone model).
  2. Check for software updates (if touch works intermittently).
  3. Test in Safe Mode (to rule out app interference).
  4. Backup data (if possible via mouse/OTG adapter).
Puan 0
Yorum Ekle
Display ka price
Update (03/19/26)
Folder price
Puan 0
2 Yorum:
Unless iFixit actually carries the part you want, I'm afraid the price is up to you to find. We provide information as best we can on how you can repair your own device, but it's up to you to locate the part and any tools needed. If they have the part, it will be listed on the device page in the upper right hand corner of this page. In this case, it doesn't appear they carry any parts for the Oneplus Nord CE 2.
Without knowing where in the world you are located, any estimates we make will probably be wrong anyway since we don't know where you can source your parts from. AliExpress ships worldwide, and you can often find parts on eBay and Amazon as well.
tarafından
Filipino->English translation:
Maliban na lang kung ang iFixit ay talagang nagtitinda ng piyesang gusto mo, sa palagay ko ay nasa iyo ang presyo. Nagbibigay kami ng impormasyon sa abot ng aming makakaya kung paano mo maaayos ang iyong sariling device, ngunit nasa iyo ang paghahanap ng piyesa at anumang kagamitang kailangan. Kung mayroon sila ng piyesa, ililista ito sa pahina ng device sa kanang sulok sa itaas ng pahinang ito. Sa kasong ito, tila wala silang mga piyesa para sa Oneplus Nord CE 2.
Kung hindi alam kung saan ka matatagpuan sa mundo, ang anumang pagtatantya na gagawin namin ay malamang na mali dahil hindi namin alam kung saan mo makukuha ang iyong mga piyesa. Nagpapadala ang AliExpress sa buong mundo, at madalas kang makakahanap ng mga piyesa sa eBay at Amazon.
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
my phone display is not showing any thing as display is not cracked
Puan 0
1 Yorum:
See the Most Helpful Answer for what to do.
A display can fail without showing any visible signs of damage.
tarafından
Yorum Ekle
How i fix it
Puan 0
1 Yorum:
What's wrong with your phone? Is it the same model as the original question? If you're asking about replacing the screen, then I'm not clear why you didn't just read the answer that's already been given.
tarafından
Yorum Ekle
Yanıtını ekle
Daddy119 Roxxx sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 70
Her zaman: 2,145
