Ana içeriğe geç
Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
MacBook Air M2 display not functioning after display replacement
The Macbook Air, on the latest MacOS 15.1 Beta, has gone through a display issue so I had to replace the display. I've worked on many apple devices as I run a repair shop, however in this case, when I replace the display, it functions as usual for about 5 mins and it completly goes black. Tried with a new display in my shop, same outcome. The Mac runs completly fine with the broken display, and when connected to the external screen.
Bu iyi bir soru mu?
Puan 0
4 Yorum
Where did you get the display?
tarafından
I've got one from amazon, and the second batch from ifixit.
tarafından
To be clear the Amazon display was a factory fresh display and I believe that is also true with the iFixit display as well.
What happens when you boot up under iOS 14? Using Beta versions might change things which has happened before.
tarafından
Did a DFU restore to downgrade it to macOS 14, still the same outcome. Maybe apple updated the firmware to block third party repairs?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@chanhyeong49990 - That was my thinking as well! While not pleasant from a cost perspective I think you’ll need to get the display via the Apple self repair option so you gain access to the paywalled calibration tool which can only be gotten getting the part directly from Apple. the other option which is still a gamble is to locate a used display as that had worked before. But that may fail in the same way.
If you can write a complaint to either the EU or US consumer protection agencies. As both have the right to repair legislation either coming or enforced.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Cheers Dan! I’ll try to see how it goes after the official release of the MacOS 15, and sort this out. Fingers crossed that it will not be a feature blocked by apple to prevent self repairs
tarafından
@chanhyeong49990 - I hope so too!
tarafından
Yorum Ekle
Yanıtını ekle
Chanhyeong Kim (Chan) sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 528
