Ana içeriğe geç
Panasonic TX-32LX70, Panasonic marka 32 inçlik bir LCD (sıvı kristal ekran) yüksek çözünürlüklü televizyondur.
Sound and no picture
Please guys, I need some help, my TV is a Panasonic model TC-32LX70LB, and i don't speak english very well, what happen is that when I turn the tv on, the sound works normally, but the image does not appear, and makes a sound like something is trying to work mechanically, i don't know how to explain exactly, but after some time, the image started to appar gradatively, however after a few months of that now only works the sound
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
@marjorieronzani you are not saying if your power LED blink when your pictures is dark. First you want to try all other video inputs, things like HDMI, Component etc. Next try to see if your TV still shows the TV menu when you push that on your remote.
Now turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. Do that in a darkened room. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components.
Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Mevcut bir soruya görsel ekleme for that so we can see what you see. It is possible that this is either a power board or a backlight inverter.
Your TV uses CCFL tube as backlight. It is possible that these have burned out. Those function in principle the same way as fluorescent light bulbs.
If you have any trouble translating this, let us know what your native language is. We can always try to rephrase or translate the more confusing issues. Welcome to iFixit!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
MARJORIE RONZANI sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 295
