Ana içeriğe geç
Mısır patlatma makinesi onarımı için kılavuzlar.
Popcorn machine mains problem
A popcorn kettle on the bench. It was reported to trip mains fuse. When testing it I measured 1.3 kW. But kettle was marked 500 W. I opened it up and could not see or measure anything faulty. Cables and grounding was good. But there were rust on the thermostats nuts. I cleaned the nuts and rusty residue on the thermostat. Put everything back together and now the kettle measure 500W and the thermostats works. Is it possible that the thermostats was faulty due and the reason for it to draw 1.3 kW instead of 0.5kW?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@seafoamgreen absolutely. SInce everything is looking like it is in good working order, and it does not pop the mains fuse, I would say you got it fixed. Could be bad thermostat, bad connections corroded connections etc.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Sea sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 396
