Ana içeriğe geç
Dell G15 5515, Haziran 2021'de piyasaya sürülen ve Dell tarafından 5515 model numarasıyla üretilen bir dizüstü bilgisayardır. Bu sayfa, Dell G15 5515 kullanıcılarına yaygın teknik sorunlar için basit ve kolay onarım çözümleri sunmak amacıyla oluşturulmuştur.
Water Damage, still usable!
Every since I got some water damage on my laptop, the GPU is no longer detected. If you push on the righ part of the case of the laptop, you can cause a short and immediate black screen shutdown. The laptop still works amazing for CPU only tasks and even mild gaming, the battery life obviosuly improved with no GPU😂
I've been living with this for around 6 months and now I'm becoming interested in troubleshoot the MOBO and soldering if needed to fix my laptop! any reccomendations?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@jacobfromerth my number one recommendation would be to start disassembling your laptop. Use this Dell G15 5515 Service Manual to work on your laptop. Remove the motherboard and then it's time to clean it. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide It was written for an Apple iPhone3G but all the points are still pertinent to your motherboard as well.phone. While you clean your board, check for any obvious damage, like burned or missing components etc.
Until it is cleaned, everything will only be a guess. Post some well-focused pictures of your motherboard with your question. That way we can see what you see Mevcut bir soruya görsel ekleme and hopefully we can help you getting this back to "normal"
iPhone Görseli
Kılavuz
iPhone Sıvı Teması Onarımı
Zorluk:
Zor
1 - 2 hours
iFixit Görseli
Kılavuz
Zorluk:
Çok kolay
2 - 5 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Jacob Fromerth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 330
