Ana içeriğe geç
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Won’t boot, no chime, no blinks
I’ve stripped down my machine (removed optical drive, all HDDs, GPU, RAM risers) turned it on and I just get a solid SIL lamp—no blinking. The diagnostic lights on the logic board indicate “STBY” (trickle power is good) and “EFI” (EFI is done loading). “PWRG” is off which I think is a problem. I’ve tested the molex connector and I get 12.17v on one side and 5.02v on the other.
The reset button on the logic board does nothing. The fans run pretty quietly but I can’t tell if they’re at “max” or not. [edit: also changed the RTC battery on the logic board… no change in behavior]
Thanks in advance, would love to keep this ol’ gal running!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Did you try just replacing the PRAM battery?
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
Yes, sorry, forgot to mention that I tried that. I tried booting it without the battery too, no SIL blinks, same two diagnostic LEDs.
tarafından
@bryanneilon - Let’s backup here a bit, the system was working then what happened?
tarafından
@danj - good idea. I’ve had this machine for over 10 years and there have been a bunch of problems to come and go. I suppose most recently it was shutting off unexpectedly and would “restart” but get stuck with what I guess was the sound of the fans at max speed, no display, no chime. I left it to sit for a few months (this is a “fun hobby” machine when it’s not giving me a headache) before I gave it a thorough de-dusting. After removing what seemed like an enormous amount of dust, it no longer sounds like a jet engine but now just sits there with its solid SIL.
Before that, it was running pretty well with a SSD, maxed out RAM, the DosDude1 patch and Catalina.
tarafından
Yorum Ekle
Yanıtını ekle
Bryan Neilon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 117
