Ana içeriğe geç
Repair and disassembly information for Logitech's G Pro X Superlight wireless gaming mouse. Identifiable by model number MR0106. Released in December 2020.
Scroll wheel not working after installing a replacement.
The middle click was not working on the mouse so I got a replacement. After the replacement, the wheel stopped working and the middle click didn't improve also. This was also the same with the old button board.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You say you got 'a replacement' but do not specify for what: a replacement for the 'middle click' sounds strange.
Two things can go wrong here.
  1. The middle click not working: If you open the mouse you'll find the wheel shaft rests on a small micro switch. Determine if it seats properly and if you can hear a 'click' sound when pressed.
  2. If the wheel doesn't scroll, here's what I found on mine: A plastic wheel with a soft plastic/rubber 'tyre' (or tire in American spelling) covering it. My tire was slipping on its wheel - both very smooth - and the tire wasn't a tight fit any longer. I roughened up the wheel a bit and dabbed a drop of super glue on the wheel bead then re-fit the tire - problem solved.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
I replaced the hole button assembly the above is a link to what I bought
tarafından
I also, feel the click
tarafından
I can also feel the notches when I spin the wheel
tarafından
Yorum Ekle
Yanıtını ekle
james1998hodges sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 294
