Ana içeriğe geç
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
My dsi wont read games
one of my cusans was playing with it but wane he gave me it back it will not raed games
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
1 Yorum
Hi i have the same problem . I don't have an sd card and i put wifi and thats when the games didn't work anymore. I tried everything and it didn't work. I even formatted settings and everything still didn't work
tarafından
Yorum Ekle
13 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey, the slot were the games go into is most likely damaged or needs to be cleaned. If you look in the slot, there is a door that needs to be lifted up and you can see the pins that read the game.
Shine a light into the slot and see if any of the pins are bent out of position or they have a green color corrosion over them.
If you see corrosion, then you can clean it with a nail file. Just be careful, so you do not bend the pins.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
i might try it
tarafından
Yorum Ekle
Hi my DSI had the same problem, so did my sister's but hers is fixed. All she did was shake her DSI and then clean the slot with a tissue. It didn't work for mine sadly
Puan 2
1 Yorum:
Oh yeah and what door do u mean
tarafından
Yorum Ekle
well mine is a used one and it wont show
Puan 2
Yorum Ekle
I'm having the same problem :(
Puan 1
Yorum Ekle
No I found a game out side and it has a dent in it the chip is clean but my dsi xl won't read it
Puan 1
Yorum Ekle
I have the same problem
Puan 1
Yorum Ekle
Try putting a clothing tag in the game slot alongside the game. Yes, it does work, but it may take a few tries. It seems like it would break it more, I know, but I swear this happened to me and this was my solution.
Puan 1
4 Yorum:
whats a clothing tag?
tarafından
*sweatdrop*
Um...sometimes clothes have those tags that are connected by little plastic tabs. Just, if you keep trying to get the game to work, putting slight pressure alongside the game card helps.
tarafından
this is the only one here that helped me
tarafından
Did yours have blended pins or was it just dirty?
tarafından
Yorum Ekle
Try spray compressed air in the slot. There may be dust bunnies inside.
Puan 1
Yorum Ekle
Hello, I am a YouTuber who has this same problem. As soon as I find a fix it will be uploaded on my channel here.
Hopefully, when and if I upload the video it will help you out.
Puan 0
1 Yorum:
What door?I don't see a door
tarafından
Yorum Ekle
I have borrowed a dsi and simply blew into the game slot
Puan 0
Yorum Ekle
I think DSI causes issues sometimes in reading games. You have to try it again and again and hopefully, it will help.
Puan 0
Yorum Ekle
it could be dust in the slot. try using a cotton swab and rubbing alcohol in the slot. if that does not work, take it to a repair shop or if you know how to repair it, buy a replacement game card slot.
Puan 0
Yorum Ekle
One possible solution is to clean the contacts on both the game cartridge and the DSi console using a soft, dry cloth. This can help remove any dirt or debris that may be interfering with the connection.
Puan 0
Yorum Ekle
Yanıtını ekle
gaynordante sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 40,564
