Ana içeriğe geç
Öncelikle hakemler tarafından kullanılan kablosuz iletişim cihazları.
Loose connection inside the rectangular rubber-coated case
Where would I start if I wanted to take this apart and re-solder it? Obviously would prefer to avoid any permanent damage. I've tried sliding a knife around the edges (there's a slight ridge where what appears to be two halves were pressed together), but I'm guessing I need heat and/or some kind of solvent. Anyone have experience taking apart weatherproofed / sealed electronics?
Resim
Resim
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
@miketexter post a couple of well -focused images of the "rectangular rubber-coated case" with your Question. that way we can see what you see and hopefully assist you further. Mevcut bir soruya görsel ekleme
tarafından
@oldturkey03 done, thank you for that tutorial :)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@miketexter that looks like it's very well glued together. If this would be mine, I'd take an exacto knife (or a razor blade) and cut through the seam. After completing the repair, I'd use some silicone rubber glue to reassemble the case.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mike Texter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 188
