Ana içeriğe geç
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
20 Soru Tümünü görüntüle
How can I repair my L button?
I recently bought a N2DSXL for my brother, but the L button on it is broken. I press it, and it doesn't give that click that happens when you press in on it. It also does not recognize it as being pressed. (I tested in the HOME Menu) I'm assuming the trigger switch inside it is broken. Where can I find replacement parts for it? And do I need any specific tools for this? Thanks in advance!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is easily the biggest design flaw with this console, the shoulder buttons love to break off and tear the copper pads out. Hold it up to your ear and give it a shake. Hear something rattling around inside? That's your L button.
First step is to assess the damage. Take the motherboard out and look for the button mounting point. If all the pads are there, great! (also, you're very lucky). Just solder in a new button and you should be good.
If you're not so lucky and some (or all) pads are gone, it gets trickier, and you'll have to scratch some of the solder mask off to make new contact points. You can do this right next to the pins, and solder directly to them, or pick a point further along the trace and connect it with some trace wire. The two side (ground) mounting points, though, provide most of the structural integrity and should be connected directly.
The button is the same one used in other 3ds models + joycons, and can be found with a search like "3ds replacement shoulder buttons".
As for tools, you'll need the ones listed in the motherboard guide, as well as some form of soldering setup. Doesn't necessarily need to be fancy, just enough to attach that button. It's doable with a fine soldering iron, but maybe easier with hot air. (Can't be sure, i've never used hot air)
Good luck! We're all here if you have more questions
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Thank you for the info! I'll buy the parts, will update to see how it goes!
tarafından
Also, I have another question. I can't seem to find any replacement shoulder button parts. Where would you recommend to buy?
tarafından
@rioluandroid I'm hesitant to give out specific recommendations as i've never bought any myself, but I can point you to some listings I found after a little searching:
https://www.amazon.com/Switches-Microswi...
https://www.aliexpress.com/item/10050048...
https://www.ebay.com/itm/156245336776
tarafından
Yorum Ekle
Yanıtını ekle
OtherAndroid sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 103
Her zaman: 316
