Ana içeriğe geç
A 35mm SLR introduced by Asahi Optical Company in 1964. It was one of the first SLR's available with Through-The-Lens (TTL) metering.
How to Remove the Back Cover/Film Door?
I attempting to modify this Pentax however it would require removing the Back Cover/Film Door to place a 3D printed back.
Is there a way to easily remove the Back Cover without fully disassembling the camera?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yes, the back hinge can be removed by carefully peeling back the leatherette exposing the screws which hold it and the back cover onto the body. Do to age, the covering will be brittle. A good substitute is suede leather, I’ve used elbow patches for the needed material.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Specifically, you want to peel the front leatherette. The edge by the door hinge. Some isopropyl alcohol can be used to soften the adhesive. In my experience, Spotmatic leatherette is pretty robust and rarely needs replacing, but you never know.
tarafından
Yorum Ekle
Yanıtını ekle
Jenna Forest sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 223
