Ana içeriğe geç
This is the 8-inch version of the smaller Fire 7. It includes 1.5 GB of RAM, a faster processor, and an HD display. The Fire HD 8 was released on June 7th, 2017.
It doesn’t charge when it’s dead
I got the tablet from a friend who told me it didn’t charge. “No problem,” I thought, so I ordered a new battery, which was charged, so I thought I could let the tablet die overnight. Well, I did, and now it’s not charging again. Now what?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@susposter779 could be a bad charging port. I am certain you have checked your charger and your charging cable to make sure that those are working properly. Next you can try and check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Since you've replaced the battery, you do want to make sure that everything has been properly connected and that all of your ribbon cables are in good (no tears, rips, holes, etc.) working order. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad charging circuit.
Schematics are not available which means that repairing the circuitry could be a real challenge.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Susposter779 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 12
