Ana içeriğe geç
I can't upgrade storage, is it possible?
I have a Lenovo Yoga 300-11IBR 80M1 - 11.6 .I thought it was a bargain and found out it was because the system drive is a 32gb one. With Windows 10 Home on it that actually leaves just over 8gb for apps and files!
I thought it was an msata drive and that I just could hop on to Amazon and buy a bigger one. I then found the full spec online, and it is actually an eMMC drive, embedded in the motherboard!
My question is the following: has anyone opened that laptop? will I found a msata slot or a sata connector in it - or am I stuck with this ridiculously small storage?
Update (10/18/24)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Yes, it is one of those where everything else is "integrated" soldered to the board. This computer should still have a HDD. I'd replace that for a SATA III SSD. Not a whole lot of other things you can do with it. To work on your computer. download the service manual from here
Update (10/18/24)
@muhammednasimap Okay, looks like your board does not have a SATA connector. Unless there is anything under the black tape. In that case it can't be upgraded. Looks like you have to make do with the way this machine originally came. .
Bu yanıt yardımcı oldu mu?
Puan 0
10 Yorum:
Could you tell me how to do it
tarafından
@muhammednasimap you could download the service manual from the link (Blue color) in the original answer. Check for HDD in there. You could also use something like this video
tarafından
@oldturkey03 it seems I don't have that connector of hard disk in my laptop
tarafından
@muhammednasimap can you take a picture of what you are looking at and post it with your question? Let's see if we can figure this out.
Adding images to an existing question
tarafından
@oldturkey03 i have added it
tarafından
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Muhammed Nasim A P sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 101
