Ana içeriğe geç
Screen seperated from the phone
I have the F91 5g and the screen came out of the phone I don't see where the screen is supposed to connect back into the phone. Does anyone have pictures to show how this is supposed to be reassembled? I see what appears to be where the cable connects through the system however I don't see a connector there.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Jason! For your F91 5G, Here are some you can follow:
  1. Check for screws: Make sure there are no screws or clips holding the screen in place. Sometimes these can be hidden under stickers or rubber pads.
  2. Locate the connector: The screen should have a flex cable that connects to the motherboard. Look closely at the area near the battery or main chip; it may be under a small cover or bracket that needs to be removed.
  3. Use a magnifying glass: If the connector is small or difficult to see, a magnifying glass can help you locate it better.
  4. Consult repair guides: iFixit often has detailed guides with pictures for disassembling and reassembling specific phone models. This might give you a clearer idea of how the screen connects.
  5. YouTube videos: Search for disassembly videos specific to the F91 5G. Visual demonstrations can be incredibly helpful.
  6. Avoid forcing connections: If you don’t see an obvious place for the connector, double-check that you have the correct screen and that it hasn’t been damaged.
  7. Happy Fixing!
(Formatted by Ai for easy reading. Never written)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jason Howell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 167
