Side panel wont open
The lever on the side of the mac wont come out fully, and because of that i cannot open the side panel. Any tipps to how I can fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
SOLVED! Turns out there was a loose screw stuck in the latches inner part and because of that you couldn’t pull out the latch fully. The solution I came up with was to turn the whole mac upside down dislodging the screw.
Bu yanıt yardımcı oldu mu?
Is the lock enabled? You could try a little WD40 sprayed into the handle area. Don’t over do it, a little goes a long way.
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 205
