Dell fan making noise
How to fix noisy fan
Bu iyi bir soru mu?
@kglen there is never a good way to fix a noisy fan. I suggest that you replace it with a new one. your model should have two fans, and I would change both. Once one fails the other one is usually close behind. Remember that it's this relatively inexpensive component that essentially keeps your computer running safely. Also, make sure that all air inlet and heatsinks are properly cleaned and free of any major dust and debris. Use the Dell Precision 5550 Service Manual to work on it.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 418
A noisy Dell laptop fan is often caused by dust buildup, high CPU usage, or restricted airflow. Clean the air vents, place the laptop on a hard, flat surface, and close unnecessary background applications. If the noise continues, the cooling fan may need inspection or replacement by a qualified technician
dellauthservicecenterraipur tarafından
