Ana içeriğe geç
I want to change the usb ports
My usb ports are damaged. I want to fix them
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
@sleshi damaged how? What happened to them? Why do you think they are damaged? What have you checked?
tarafından
The slit found inside the ports is broken.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@sleshi you have one USB port that is soldered to the USB/card reader board. The part number for that board on a HP 15-db0000 is L20448-001. The other two USB SuperSpeed ports are soldered to the motherboard. For that you need to either match replacements ports by dimension and contact orientation or get a broken board from places like ebay etc. and harvest the ports from there. Personally I would find a motherboard to use as a donor board.
To work on replacing the USB ports, you will have to remove the motherboard. Use the Maintenance And Service Guide to work on your model.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
depending on model and which usb port is damaged, try putting model number into ebay, and look for a usb board, it could either be ports on the logic board or it could be easily replaceable ports just depends on which side has the damaged usb port
Puan 0
Yorum Ekle
Yanıtını ekle
Sleshi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 35
