Ana içeriğe geç
Philips Wake-Up Light Alarm Clock with Colored Sunrise Simulation, 5 Natural Sounds & Radio. Released in April 2017. Model number: HF3520/60.
13 Soru Tümünü görüntüle
How to fix lamp always on?
I bought a HF3520 second hand, and everything works fine except that whenever the lamp should be totally off it is at full brightness.
For instance, if I press the lamp button the lamp turns to however bright/dim I've set it, but if I press it again it turns to full brightness.
I've tried disconecting it for a while, and reseting it but nothing has worked.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Did you review the owners manual? Here’s where you can download load it HF3520 info
I’m suspecting the settings are off either AM - PM confused or the time zone setting.
Bu yanıt yardımcı oldu mu?
Puan 0
6 Yorum:
Thanks for the reply!
I checked the manual. I changed the time setting and that didn't fix the issue, also the lamp function should be able to be turned on and off regardless of the time.
tarafından
@ericastrue - Then the switch is bad or the logic which controls the lamp.
I have HomeKit version of the lamp and have it programed with Siri as well via my HomePod Mini. My first unit was defective as the control logic was bad.
tarafından
I see, maybe it's a different model as with mine I don't think I can conect the device with other devices.
tarafından
@ericastrue - Sorry, I may have confused you. If the settings are correct then it’s the switch or the logic which controls the light. Best to find someone with micro electronics skills to help you locally.
tarafından
Someone on reddit told me about having a similar issue, and in his case it was a fawlty capacitor. I've dissassembled the light today and I've found that that same capacitor has a slight bulge on the top in my unit. I'll try to test it tomorrow and replace it, and I'll get back to this thread.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Eric Astrue sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 73
