Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
20 Soru Tümünü görüntüle
Strange charging behavior with no amber led
I bought a MBA 11" as not tested, and it does not charge, or show any led on the charger. How ever, when i disconnected the interconnect cable to the I/O board and connected the charger, the charger lit up green. After i reconnecter the interconnect cable and plugged the charger back in, the green led lit up and faded shortly after. I checked the charger with my MBP 2015 13" and it works flawlessly. what could cause this behavior?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
1st step would be to install https://www.coconut-flavour.com/coconutb... and see what the battery status is.....
tarafından
Are you using a MagSafe 1 to MagSafe 2 adapter?
Like this one? https://store.storeimages.cdn-apple.com/...
The MagSafe to MagSafe 2 Converter allows you to use the MagSafe connector on your LED Cinema Display, Thunderbolt Display, or MagSafe Power Adapter to charge your MagSafe 2-equipped Mac computer.
tarafından
I am using a genuine Apple Magsafe 2 charger. The macbook is completly flat, so i can‘t imstall Coconut battery
tarafından
@junkmaccol17375 - Did you replace the cable and I/O board?
tarafından
I do not have those replacement parts on hand right now, but will order them soon
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It sounds like either the cable or the board it’s self has a problem. Inspect both looking for damage, the cable or board might have damage within the connectors or there might be liquid damage. Here’s the guides for both and they both offer parts info as well
MacBook Air 11" Early 2015 I/O Board Görseli
Kılavuz
MacBook Air 11" Early 2015 I/O Board Replacement
Zorluk:
Orta
40 minutes - 2 hours
MacBook Air 11" Early 2015 I/O Board Cable Görseli
Kılavuz
MacBook Air 11" Early 2015 I/O Board Cable Replacement
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Junkmac_collector sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 18
