Ana içeriğe geç
HP Compaq 8200 Elite, üst düzey ofis ve tasarım işleri için tasarlanmış, küçük form faktörlü, iş istasyonu sınıfı bir masaüstü bilgisayardır. Teknisyenlerin sürücüleri ve kartları hızlı bir şekilde değiştirmesine olanak tanıyan, oldukça onarılabilir bir tasarıma sahiptir.
Why is my system unit(desktop) not working
I was playing game with my desktop and I heard weird sound. Then, the desktop went off. It cannot be turned on again
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Brainy! It is most likely your PSU (Power supply) You still should:
  1. Check the Power Supply:
    • Power Cable and Outlet: Ensure the power cable is securely plugged in and test the outlet with another device to confirm it’s working.
    • Power Supply Unit (PSU): The sound you heard might indicate a PSU failure, especially if there was a pop or a burning smell. This can happen due to a power surge or component failure. Consider testing the PSU with a multimeter or swapping it with a known working one if you have access to one.
  2. Inspect for Visible Damage:
    • Open the case and look for signs of burnt components, particularly around the PSU and motherboard. Swollen capacitors or burnt marks indicate a likely point of failure.
  3. Perform a Basic Power Reset:
    • Disconnect the power cable and hold down the power button for about 15 seconds to discharge any residual power. Then, reconnect the cable and try turning it on again.
  4. Motherboard Diagnostics:
    • Check if there are any diagnostic lights or error codes flashing on the motherboard when you try to power it on. Some HP desktops have diagnostic LEDs or beep codes that can indicate specific issues.
    • If the PSU appears functional but the system still won’t turn on, the motherboard itself may have failed.
If none of these steps help, the most likely culprits are a failed PSU or motherboard.
(Formatted By ChatGPT 4o-. Never written)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Brainy Aikins sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 284
