Ana içeriğe geç
Samsung Galaxy Watch Active, Güney Koreli bir elektronik şirketi olan Samsung Electronics tarafından tasarlanan, geliştirilen ve üretilen bir akıllı saattir. SM-R500 model numarasıyla tanımlanabilir. Mart 2019'da piyasaya sürülmüştür.
need to replace the battery I think
After 2 months of wrecking my head, trying to use this Amazon.com: Ubrokeifixit Galaxy Watch Back Rear Lens Glass with Tape Replacement for Samsung Galaxy Watch 46mm SM-R800 R805/Galaxy Watch 42mm SM-R810 R815 Black(Rear Cover NOT Included) : Cell Phones & Accessories
There are 0 videos on how to use this kit... back started falling off. I was able to tape it on and it started working again, then just today it fell off again.
I have moved to the next step in trying to get this thing to work again, replacing the battery. What is need to do this.
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey there,
iFixit has a fairly comprehensive battery replacement guide for this device, which has a list of tools that you will need to replace the battery. I was also able to find a kit for the replacement battery that should have all you need, but I would double check to make sure that it is correct for your specific watch.
One last thing, I was also able to find a video guide for replacing the rear glass, that seems to be using the same kit you got. If you want to try replacing the backglass again, then that should be useful.
Best of luck to you.
Bu yanıt yardımcı oldu mu?
Puan 1
16 Yorum:
Thank you. Trying to save the battery replacement as a last resort. Still trying to figure out how to use the ubrokeit kit I bought on amazon.
Does Ifix it have a kit comparable to those on amazon, that you linked me?
tarafından
@mnmacd iFixit has the tools, but sadly not the precut adhesive.
tarafından
Thank you, would you mind linking the toolkit?
tarafından
Phillips #00 Screwdriver
Will I need this as well? It came up as recommended with the tripoint
tarafından
11 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
mnmacd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 536
