Ana içeriğe geç
battery replacement gone wrong
so i just finished replacing my battery after watching youtube videos (i'm a beginner) and now my screen dosent show anything, i unplugged the connector for the new battery and connected the old battery and that one didn't turn anything on either.. keep in mind my phone was working fine other than a low battery health, can anyone tell me what this problem could be from?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Its sounds like you have damaged your screen during removal... easily done!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Most commonly an issue such as yours is related to either the connector on the motherboard or at the end of the screen's flex cable. If you're new to those delicate little plugs, it's pretty easy to damage them by pressing too hard or not getting the plug lined up exactly right before pressing the connector in place.
I'd suggest unplugging the display cable then check it carefully on both sides with a magnifying glass and a bright light. You'll be looking for bent or broken pins; bent ones can sometimes be straightened with fine tip tweezers, but missing pins will either mean replacing the connector on the motherboard or getting a new screen.
Assuming the pins all look straight and present, you'll want to clean both sides of the connector with 90% or higher concentration isopropyl (rubbing) alcohol, give it a minute to dry, then carefully reconnect the display. Pay attention to the comment at this point in the battery replacement guide:
Give that a try and let us know what happens.
Puan 1
Yorum Ekle
Yanıtını ekle
Tammy Allen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 174
