Ana içeriğe geç
22 Eylül 2021 tarihinde piyasaya sürülen Microsoft Surface Pro 8 için onarım rehberleri.
FPC flex cable, Microsoft Surface Pro Signature
My Microsoft Surface Pro Signature keyboard suddenly stopped working, I tried several software solutions and nothing worked. Then I proceeded to disassemble the keyboard, and I found that the internal flex cable was damaged, as it had very small tracks, it was impossible for me to reattach them, and I ended up damaging the flex cable even more. Integrated in this flex are the backlight tracks, signal tracks and the tracks that power the wireless charging of the slim pen 2. The flex cable that connects the detachable keyboard to the tablet is broken, therefore the keyboard stopped working completely and it also does not charge the wireless pen. I uncovered it completely, and the flex is completely separated from the base of the external connector of the keyboard that is inserted into the tablet. I would like to know where I can get the schematics for this connector, know how the flex is connected to the connector pins, how the keyboard backlight is connected and how it is connected to the keyboard motherboard. or if anyone knows the function of the 6 pins of the connector, or if they could help me with some other solution. Please The FPC cable contains the following numbering: "MFS M1110070-012"
Resim
Resim
Resim
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum:
Hi Sebastian,
I have this same problem with broken flex ribbon exactly as per your photo. I am unable to repair the ribbon due to the extremely small tracks. Were you able to fix or source a new ribbon?
Thanks
David
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
FPC cable has 7 tracks. But connector has 6 terminals
Resim
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Sebastián Godínez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 91
Her zaman: 530
