Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Why is only low battery display popping up after battery replacement?
Replaced my battery per instructions but laptop does not boot. It only shows low battery display when plugged in. Light on charger will turn orange for 20-30 seconds then flash to green for 5 seconds before repeating again.
Left charger in for 20+ minutes and still nothing.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Are you using an 85W charger? If you're using a lesser wattage it may not be enough to power on the 15-inch from a fully discharged state. Otherwise, you could try an SMC reset. If everything else is correct, it could be the case that the battery you installed is faulty which unfortunately sometimes happens.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Yes, using an 85W charger and have done an SMC reset and still the same issue.
tarafından
Darn, that makes me think the issue lies with the battery you installed. Were you getting these symptoms before the battery replacement? Good luck!
tarafından
Yorum Ekle
Let’s get a better view on things. Install this gem of an App! CoconutBattery paste a screen snapshot of the Apps main window and post it here so we can see it.
Puan 0
Yorum Ekle
Yanıtını ekle
AB1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 35
