Ana içeriğe geç
Rebel T6, 1300D veya Kiss X80 olarak da bilinen model, Nisan 2016'da Canon tarafından piyasaya sürülmüştür.
Why not power on?
Why not power on ? How to fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here's some troubleshooting steps you can start with to try to narrow down the problem:
  • Try using a different battery. Make sure it is fully charged.
  • Visually inspect the battery door switch to see if it's damaged and no pieces are broken off of it. This is a tiny switch located underneath the battery door (see image below) that tells the camera if the battery door is open. The camera will not power on if this switch is not pressed down, therefore a broken switch could prevent the camera from turning on.
Resim
  • Take a flashlight and shine it up against the LCD screen at an angle. If you can see a faint image, the issue is with the backlight on the LCD screen
Also there should be a red LED indicator light on the bottom right on the backside of the camera. Does this light blink at all when you try to turn on the camera?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
manoj khopade sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 38
Her zaman: 480
