Ana içeriğe geç
macOS Uyumluluğuna Sahip 27 İnç LG UltraFine 5K IPS Monitör
Monitor no longer powers on
The monitor no longer powers on, and does not connect or power my MBP. It sounds like this is a common issue. Has anyone else solved?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
@harrisehsan does the power LED still come on? What have you checked? What is the exact model number for your monitor?
tarafından
@oldturkey03 No it does not. Nothing happens at all. There is no real sign it is working. But I spoke to a repair shop that said the motherboard has known issues that cause this, so it should be repairable. Model number is 27MD5KA
tarafından
Replace the motherboard then
tarafından
@senopatib I'm hoping someone here can explain how
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
I couldn't find the exact monitor that you have but from searching maybe this could help:
https://youtu.be/ytKg1dsMv4U?si=pjGamcu9...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
@harrisehsan don't replace anything yet until you have at least had a chance to take a look at it. Use this guide LG UltraFine 5K Teardown to get to the boards. Then post some well-focused pictures of everything with your Question. That way we can see what you see and hopefully assist you further. Adding images to an existing question - iFixit Repair Guide
I expect this to be an issue with the power supply.
iFixit Görseli
Kılavuz
Mevcut bir soruya görsel ekleme
Zorluk:
Çok kolay
2 - 5 minutes
LG UltraFine 5K Görseli
Kılavuz
Zorluk:
Orta
Puan 0
Yorum Ekle
Yanıtını ekle
Harris Ehsan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 448
