Ana içeriğe geç
Controllers for the Valve Index VR Headset released on June 28th 2019.
Replacing the handstrap adjustment button spring for the controllers
The handstrap is intact, but over all this time of putting it on and taking it off, my handstrap, particularly in my right controller comes loose from open handed movement and isn't as tight as it used to be. I feel like the spring in the adjustment button at the bottom of the controller where the handstrap feeds has loosened, this kind of problem is the type that happens way out of warranty from continuous use over years.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The issue here is that in order to access this part you need to be able to separate the two halves of the handle, and in order to do that you need access to a screw at the bottom of the tracking ring which is cemented shut and can't be reached without destroying the tracking ring's shell. Consider tying a knot on the other end of the handstrap cord so it can't go through the hole and thus prevent the strap from slipping out.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Elysium sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 157
