My 2015 BMW F700 GS won’t start
Hi,
My 2015 F700 GS won’t start, the battery is at optimum health and has no issues.
When I start the ignition the lights and all things on dashboard do come alive like it would normally, no sign of oil required or low gas.
The fuel pump also makes the sound of one bleep indicating it is working.
What could possibly be the issue?
I am in cold weather, minus 5 but the motorcycle was not starting since November 4 which was not cold at all.
Please help.
Thank you.
Bu iyi bir soru mu?
Puan
0
@sanketmore does the engine crank over (is the starter working) or does it not do anything?
oldturkey03 tarafından
Yes, the starter works. But engine doesn’t fire up.
Sanket More tarafından
@sanketmore one more check. Do you have spark on the spark plug? I usually just pull the plug connector and use a different sparkplug and hold it close to the engine block. Then try to start your bike. See if you have spark.
@oldturkey03 I need to check that, where can I locate the spark plug?
@sanketmore check something like this video at about 5:20 to learn about the spark plugs
