Ana içeriğe geç
Acer Nitro 5 AN515-43, 2019 yılında piyasaya sürülen bütçe dostu bir oyun dizüstü bilgisayarıdır. Genellikle NVIDIA GeForce GTX veya AMD Radeon RX serisi grafik kartlarıyla eşleştirilmiş AMD Ryzen mobil işlemcilere sahiptir.
Heating issue. Thinking of thermal paste it again?
My laptop is heating a lot. I'm thinking of changing my thermal paste and cleaning dust inside it also, or i should do something else, like expanding RAM.
Please help it's heating like a heater in cold season.
Thanks 😊
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Is the fan running and blowing air? I would start with that, and with cleaning the fan and heatsink it blows air through with some compressed air - try to prevent the fan from spinning while you clean it (clean it while it is turned off).
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Firstly, check the temperature of the CPU using Speccy.
Is it also hot when idle? If so, then some background process might be using the resources.
Check Task Manager process list sorting by CPU usage, to see what's using the CPU power.
Then clean your computer with some compressed air, maybe that'll be enough.
However if you haven't replaced the thermal paste in some years, it would be a good idea to do so.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Aakash sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 259
